LibreCAD - forum locked! please use https://discourse.librecad.org/ now
Advanced Search
New Topic
People
1
125
126
127
128
129
130
131
136
Topics
(4736)
Replies
Last Post
Views
Sub Forum
Using Templates in LibreCAD
by Rallaz
2
by Rallaz
Tips ' n ' Tricks
Default settings for new drawings
by Frédéric
3
by Frédéric
LibreCAD-user
LibreCAD compatibility issue with AutoCAD (selection window).
by ClaudeQC
0
by ClaudeQC
LibreCAD-dev
How to change the scale?
by Carnyx
2
by Rallaz
LibreCAD-user
Librecad 2.0.4 Alpha for OSX
by jam68
6
by p2ranger
LibreCAD-user
LibreCAD "TEXT" entity support tests.
by ClaudeQC
0
by ClaudeQC
LibreCAD-dev
Offset possible bug/issue
by grypokx
0
by grypokx
LibreCAD-dev
Undo in commandline in polyline possible bug
by grypokx
0
by grypokx
LibreCAD-dev
2.0.0alpha3 opinion after testing
by grypokx
6
by maqifrnswa
LibreCAD-user
European portuguese translation
by forave
6
by Vicent Fornés
LibreCAD-translate
How to set the scale for printing?
by jkop
14
by vidyadhara buddhiraj...
LibreCAD-user
Text problems when I open a .dxf file, created in LibreCAD, with AutoCAD 2012
by shane7
3
by Michal
LibreCAD-user
Getting copies of the tool icons
by BigAl
3
by BigAl
LibreCAD-user
Installing a new version
by BigAl
3
by dxli
Troubleshooting
Hi from BigAl
by BigAl
1
by sp1der
New user - Introduce yourself
Draw line by only specifying length?
by tesco
3
by sp1der
LibreCAD-user
Mirroring TEXT and Single TEXT Class
by boukyaku
1
by ClaudeQC
LibreCAD-user
Ubuntu 10.04 LTS
by jthornton
6
by jthornton
LibreCAD-user
can't find lmparser
by daniel
1
by dxli
LibreCAD-dev
can't find lmparser
by daniel
0
by daniel
LibreCAD-dev
dimensions decimal digits
by Kyriakos
0
by Kyriakos
LibreCAD-user
A way to separate from Windows
by vipeca
1
by dxli
Error compile: ‘class QDateTime’ has no member named ‘msecsTo’
by diegoroman17_2
4
by diegoroman17_2
LibreCAD-dev
Dimensions drawing
by janatem
3
by dxli
Suggestions & Feedback
keycodes for the command line
by sp1der
0
by sp1der
Tips ' n ' Tricks
nice program
by simulat
1
by sp1der
Why do we now allow advertising in this forum?
by sp1der
8
by sp1der
LibreCAD-user
Linetypes aren't working when I open LibreCAD .dxf files with AutoCAD or eDrawings
by shane7
0
by shane7
LibreCAD-user
is there ttf2lff for windows
by claus82
4
by ClaudeQC
LibreCAD-user
Run issue (Fedora 16, DBus, KLocale)
by someguy
10
by dxli
LibreCAD-dev
When I want to insert text, all I get is a rectangle
by Lagaffe
2
by Lagaffe
LibreCAD-user
Help from within LibreCad
by Chak
1
by dxli
Troubleshooting
Bug about handling Chinese
by jak
2
by dxli
Troubleshooting
Updates for 2.0 (Ubuntu) do not distinguish the thicknesses of the lines (SOLVED)
by joaclint
6
by joaclint
LibreCAD-user
Use raw data from survey data collector
by Dave
8
by dxli
LibreCAD-user
1
125
126
127
128
129
130
131
136
Free forum by Nabble
Edit this page
