LibreCAD - forum locked! please use https://discourse.librecad.org/ now
Advanced Search
New Topic
People
1
85
86
87
88
89
90
91
136
Topics
(4736)
Replies
Last Post
Views
Sub Forum
Bug? - entity ordering tool won't work after several uses on same entities
by Lambertus
0
by Lambertus
Suggestions & Feedback
Hatch entity order relative to bordering lines
by Lambertus
0
by Lambertus
LibreCAD-user
Can't compile Librecad
by savio
2
by savio
LibreCAD-dev
Lost the command line
by KurtA
2
by kent
LibreCAD-user
Custom size of objects and placement
by oc3ansoul
2
by oc3ansoul
Troubleshooting
New CAD N00b
by oc3ansoul
0
by oc3ansoul
New user - Introduce yourself
LC doesn't ask for angle or radius
by humulus
2
by humulus
LibreCAD-user
workaround to ltscale
by savio
1
by dellus
Troubleshooting
fonts
by zohir
2
by ravas
LibreCAD-user
An easy method orthogonal lines with command line
by jaise
6
by dellus
LibreCAD-dev
MacOS LC versions fooled by El Capitan
by Cantar4
8
by Cantar4
Troubleshooting
Cut a line across a rectangle
by sayang
8
by sayang
LibreCAD-user
2.2.0
by ravas
6
by ravas
LibreCAD-dev
Patch Version 2.1.1
by ravas
0
by ravas
Announcements
Problems with compiling source code.
by Barry Say
3
by ravas
LibreCAD-dev
v2.1.0 unusable - fatally slow with larger files
by norrsken
16
by jaise
Troubleshooting
Learning to use blocks
by Jimts
6
by Jimts
LibreCAD-user
Couple of suggestions concerning Build 2.1.0
by kent
1
by ravas
Standalone Script to find the length of Entity in DXF Files
by rahulbhansali
0
by rahulbhansali
LibreCAD-dev
DXF read gives only points, no lines 2.1.0
by PCB.Wiz
13
by PCB.Wiz
LibreCAD-user
2.1.1
by ravas
1
by ravas
LibreCAD-dev
Problem importing DXF
by Brigo
3
by PCB.Wiz
LibreCAD-user
Problem in libdxfrw library
by Monisha
1
by ravas
LibreCAD-user
Tangent 2 Circles, Radius - How does it work?
by sashman
6
by sashman
Troubleshooting
Change Rotation Direction To Measure Clockwise instead of Counter-Clockwise
by Tango
3
by LordOfBikes
LibreCAD-user
Do you use the cal command?
by ravas
3
by ravas
Polls
Text and MText - No Dock or Widget Icon or Button
by Tango
3
by Tango
LibreCAD-user
Kris from FRANCE
by KRIS
6
by Cantar4
BLOCK AND CONTOUR TRACKING BLOC ET SUIVI DE CONTOUR
by KRIS
2
by KRIS
LibreCAD-user
Greetings from Brazil
by benso
2
by LordOfBikes
Entering absolute dimensions
by sayang
2
by sayang
LibreCAD-user
Printing Issue
by rdorsch
2
by rdorsch
LibreCAD-user
Dimensions of slopes
by Mauricio
1
by dellus
LibreCAD-user
Display Grid On Printout Or Exported PDF or Image
by Tango
4
by Tango
LibreCAD-user
Command line
by rvjames27
2
by kent
LibreCAD-user
1
85
86
87
88
89
90
91
136
Free forum by Nabble
Edit this page
