LibreCAD - forum locked! please use https://discourse.librecad.org/ now
1 ... 13141516171819 ... 136
Topics (4736)
Replies Last Post Views Sub Forum
Pietdriver New to Cad by Pietdriver
2
Pietdriver by Pietdriver
New user - Introduce yourself
Arthur Emmanuel Simplified polyline by Arthur Emmanuel
3
sand1024 by sand1024
LibreCAD-user
blindmessenger DXF Import DImension scale by blindmessenger
5
LordOfBikes by LordOfBikes
LibreCAD-user
Arthur Emmanuel MText to Text by Arthur Emmanuel
0
Arthur Emmanuel by Arthur Emmanuel
LibreCAD-user
Arthur Emmanuel Clone by Arthur Emmanuel
2
dxli by dxli
LibreCAD-dev
BLehmann Loosing line type when exploding a block by BLehmann
1
Troubleshooting
osteinjr select the entity by osteinjr
1
LibreCAD-user
legrady Miss information about Modify Menu by legrady
0
legrady by legrady
Suggestions & Feedback
Jubiaudio Is LibreCAD part of LibreOffice? by Jubiaudio
1
Jubiaudio by Jubiaudio
LibreCAD-user
AHG Screen cuts off lower part of characters in Status bar by AHG
11
jrivington by jrivington
Troubleshooting
dxli High priority tasks for 2.2.2 by dxli
11
dellus by dellus
LibreCAD-dev
Mike Pitch Print is coming out blank by Mike Pitch
5
Mike Pitch by Mike Pitch
Troubleshooting
artdrama186@icloud.com Text boxes by artdrama186@icloud.c...
0
artdrama186@icloud.com by artdrama186@icloud.c...
LibreCAD-dev
javen dxf2pdf output is mostly empty by javen
1
dxli by dxli
Troubleshooting
Arthur Emmanuel Mirror in Insert the active block by Arthur Emmanuel
0
LibreCAD-dev
Arthur Emmanuel Editing using the dimensions of the grid outside the object by Arthur Emmanuel
0
Tips ' n ' Tricks
mmikulka Adding custom Line Types by mmikulka
5
dougp by dougp
LibreCAD-user
Arthur Emmanuel Calc on Dimension Label by Arthur Emmanuel
5
LibreCAD-dev
eli Metallic microstructure in librecad by eli
1
LibreCAD-user
Cave Guy Add blocks by Cave Guy
2
LibreCAD-user
timlange3 Fillet appears to work, sometimes, only on rectangles. by timlange3
1
timlange3 by timlange3
LibreCAD-user
pichler2860 libreCAD window doesn´t open by pichler2860
4
bsorviz by bsorviz
Troubleshooting
Jopie Dradenkruis cursor by Jopie
1
dxli by dxli
Troubleshooting
ChrisT Importing to Trueview 2024 gives error with Leader by ChrisT
3
ChrisT by ChrisT
Troubleshooting
SilverGreen93 Text missing or garbeled in DXF file by SilverGreen93
10
dxli by dxli
Troubleshooting
zohir librecad slows down by zohir
4
dxli by dxli
LibreCAD-user
CraigD Question about specifying holes in file for CNC drilling by CraigD
0
CraigD by CraigD
Tips ' n ' Tricks
ChrisT Greetings from Bavaria by ChrisT
0
ChrisT by ChrisT
cad-maus Libre stürzt immer willkürlich ab by cad-maus
3
dxli by dxli
Troubleshooting
CADavid Installation of LibreCAD by CADavid
3
dxli by dxli
Troubleshooting
stealth How to trim between two lines. by stealth
8
LibreCAD-user
Travis S Scale and align function by Travis S
3
LibreCAD-user
JiaXinHuang How to use LibreCAD without UI/QT functionality? by JiaXinHuang
2
R. van Twisk by R. van Twisk
timschoenfelder Dimensions & Annotations not showing up in Windows version of LibreCAD by timschoenfelder
3
timschoenfelder by timschoenfelder
LibreCAD-user
Ferdi Creating a Polyline from Existing Segments ? by Ferdi
7
Tutorials / Manual topics
